Want to save a route in the cloud, but get fail
The value of property “linestring” is longer than 1048487 bytes. - Code:invalid-argument
User Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/127.0.0.0 Safari/537.36
Cookies Enabled: true
Screen: 1280 x 720 px - 1.125dppx
Thanks for reporting this, can you provide a few more details how you created that issue?
I could reconstruct a similar message that way:
uploaded a gpx-file with over 1200 waypoints. At the upload it should be cuttet down to 350 wpts but I set it up to 5000. Route is about 25.000 km long.
Upload was ok and route was figured out, but when I tried to save it, got the failmessage again.
Thanks for the reproduction. OK, we know what happens here, you are hitting a hard limit here right now. We do have an improvement for this planned in the coming months. Until then, I would recommend to split this route into multiple routes.
We recommend to stay below a few hundred waypoints and a few thousand km for one route - we don’t have a documented hard limit as it always depends very much on your route.
If you navigate such a long route, I would expect that there are more possible issues.
So if possible split the route into several smaller parts.
Hi, have the same problem. I want to laod a gpx file from the IBA Magic 12 rally.. 250 way points. so what i understood, for this long runs Kurviger ist not recommended. Problem still exists. correct? sorry now i have a real problem.
Moin,
Geht mal den Weg über Overlays hinzufügen.
Hier im Forum findest du noch weitere Beiträge zu dem Thema. Kann ich jetzt leider nicht so eben verlinken.
