Why is "Beeline" denoted by a Bird Icon?
This has been bothering me, so I thought I would ask.
In English, “as the crow flies” means direct distance. Hence probably the bird.
Although “beeline” actually comes from the bee. :honeybee:
Still, a bee would be more linguistically correct, a crow more understandable, and an airplane probably a bit oversized. :grinning_face_with_smiling_eyes:
Just out of multicultural interest - what symbol would you find less bothering and more appropriate?
In my native language you would say something that litteraly translates like “air line” (not “airline”), so the bird (i.e., crow) would be a good asociation. A bee would not be better - the first association would be honey or “being smart”, but “straight line” probably not even remotely.
So it is a cultural matter and there is probably no right or wrong here as long as it is well distinguishable symbol.
It doesn’t bother me and we’ve gotten used to the swallow, I think.
But if it were to be changed: Why an animal symbol? Let’s just use a line, like with all the other curves. Suggestion: 2026-10-30 08_45_10-20261030_083815011.jpeg - Windows Photo Viewer
That would then look like this:
He just asked a question about why that is the case!
For me, this is more a consistency issue than a cultural issue. Beeline should be denoted by a Bee icon or the Bird icon should be described “As a Bird Flies”. If we enlarge the discussion beyond consistency to accurate terminology, then neither bees nor birds are appropriate as neither one typically flies in a straight line. Being on the surface of a globe, the correct terminology would actually be something like “great arc” or “great arc line”, but that seems unnecessarily cumbersome. @t00thl355 asked me “what symbol would you find less bothering and more appropriate?” I like @zaphod_42 suggestion to use a thin double arrowhead line because this reminds users that this is not a road, it is simply a direction. So, to answer @t00thl355, I think the more appropriate terminology and iconology would be “Straight Line” and a thin double arrowhead line.
It is. But only in French:
I like the :bird:
It sticks out of the ordinary symbols and reminds me that I might not be able to ride that section.
:wink:
The bird was the best Icon we could find to explain what happens.
A straight line is too close to fast & curvy and could be misleading to the fastest or shortest route. Beeline is explicitly not a route, it’s just a straight connection where you have to finde the right road on your own.
If you know a better icon that works very small (important!) we can always discuss. Most icons don’t work when rendered very small or are not that explanatory.
Here’s something that might work very small. This is a mockup of screenshots from my Google Pixel 10 Pro XL Phone whose screen size is ~17.27 cm (6.8 inches) diagonal. I have deliberately created this set of points to put the Straight Line icon and the Fast and Curvy Icon near each other.
Such arrow might be also mistaken for a direction in which the route is heading, which might be misleading. Bird is fine. :wink:
