App: GPX overlay trk + wpt
(There where some previous discussions ideas but I think this one is sligthly different)
Import all: wpt+rte+trk gpx. Berlare_wpt_rte_navtrkpt.zip (1.5 KB)
  • I expected to import this gpx file into the app like this.
1. Free positoned Info waypoints(wpt) > Overlay
2. Route(rte) with the routepoints(rtept) > Routing
3. Track(trk) with the trackpoints(trkpt) > Overlay
It seems this is currently to be done by importing twice ? Correct ?
wpt+rte+trk
And than by .kurviger file transfers the (blue dot) info waypoints are lost.
Idea.
  • Import all by 3-fold import menu choice.
1. Waypoints. > Overlay or routing or both or none
2. Route. > Overlay or routing or both or none
3. Track. > Overlay or routing or both or none
  • Save also the info waypoints in the .kurviger file.
The app works similarly to the website:
  • Routing: there can be 1 route calculation from 1 source
  • Overlay: there could be multiple overlays (wpt + rte + trk)
    Is that what you are asking for?
There can only be selected one single overlay @ imports ( and 1 routing ref of course)
I expect to show 2 overlays by a single file gpx import.
trk + wpt overlay.
Do not know what the web imports. Did not test. Prefer the app use.
So it is about overlay more GPX elements (wpt, rte, trk) during the import.
Now there is the automatic or only one single selection, as with routing.
For the overlays it could be useful to overlay more or all GPX elements.
But to avoid filling the list with every possible combination,
we could add an “All” option to overlay the whole GPX?
Just try and test this with the short sample file Emux.
Of course, you decide how to present this in the best possible way.
Both info wpt’s and trk overlay are quite discreet but sure useful.
Route lines however are (imo) a bit disturbing and mostly not desired.
I suspect that the routelines are rather rarely displayed on the map.
The easiest change that can be made without complicating (more) the interface
is to change the overlay trk option into overlay trk + wpt option.
I use the GPX import quite often to import POIs (e.g. mountain passes). So I have to take care to set “Routing” to “None”, otherwise my route will be overwritten :
Would it be possible, to set “Routing” to “None” as default, if an GPX containing only waypoints (no route, no track) is selected?
The GPX has not been parsed yet.
In any case I can change the default to “None”.
Sorry for my late feedback (due to illness).
This would help for my use cases (I import GPX as overlays in most cases) - but other users might judge this different …
Would it be possible to parse the GPX before opening the UI ?
It is available in Kurviger 2.1.7 (Beta).
Do you mean changing the UI based on GPX content?
It is not possible at the moment.
works well, thanks for the implementation :+1:
