Kurviger 2.2.28
Kurviger 2.2.28 is on Google Play:
- Navigation: advanced route appearance (Pro)
Display the current route section differently from the rest of the route.
Available in “Settings | Navigation | Route appearance”.
- Navigation: display next waypoint (Pro)
Display of the next waypoint is available as an optional extra panel.
Tapping the waypoint panel, the map moves briefly to the waypoint.
Available in “Settings | Navigation | Next waypoint”.
- Navigation: select next waypoint to display (Pro)
Selection of next waypoint to display is available with long press:
- Navigation: actions and options (Pro)
Available in top left navigation panel:
  • Tap: show navigation actions
    [Skip next waypoint, Avoid roadblock]
  • Long press: show navigation options
    [Rerouting, Auto zoom, Voice guidance]
- Navigation: navigation notifications (Pro)
They can be useful with external screen devices.
Available in “Settings | Navigation | Notifications”.
- Navigation: icon color (Pro)
Separate icon color settings for navigation directions (left) and app panels (right).
Available in “Settings | Navigation | Icon color”.
- Navigation: simulation improvements (Pro)
Navigation simulation is initialized at the nearest route node.
Available in “Settings | Navigation | Navigation”.
- Navigation: Portuguese voice navigation (Pro)
Available in “Settings | Voice guidance | Voice language”.
- Routing: routing history
Offline in-memory history of latest calculated routes.
Useful for “undo” in route planning and navigation.
Available in menu “Routing | History”.
- Routing: scroll map to next / previous waypoint
You can scroll the map to the next or previous waypoint with new on-screen buttons.
(works together with the crosshair function)
Available in “Waypoints” in (long press) menu of the waypoints.
Available in “Waypoints” in (long press) menu of the route.
- Routing: split route
Available in (long press) menu of the waypoints.
- Routing: merge routes
You can merge kurviger routes (files + links) using the “Extend route” option in routing import dialog.
Available in menu “Routing | Import”.
- Routing: different track colors
The import window has a color button to select the color of the imported track(s).
Available in import window of gpx / kurviger files.
- Routing: remember imported tracks
App remembers the imported (gpx, kurviger) tracks / colors when restarting the app.
- Routing: auto hide via / shaping points
You can select the zoom level where the via / shaping points appear on the map.
Available in “Settings | Routing | Via points (zoom level)”.
Available in “Settings | Routing | Shaping points (zoom level)”.
- Routing: auto hide turn instructions
You can select (or disable) the zoom level where the turn instructions appear on the map.
Available in “Settings | Routing | Zoom level of turn instructions”.
- Routing: distance / time in waypoints list
Display distance / time of waypoints in their management screen.
The same info is in the bubbles of waypoints when tapping them.
Available in menu “Routing | Waypoints”.
- Routing: distance / time icons in waypoints list
Display distance / time icons in the waypoints management screen.
- Routing: colored waypoints in waypoints list
Display colored waypoints in their management screen.
- Routing: route planning with coordinates
Enter a marker with coordinates on the map for routing actions.
Available in menu “Tools | Location”.
- Import: GPX overlay track + waypoints
You can overlay GPX track + waypoints via a new option.
- Bookmarks: bookmark sort options
Sort function in bookmarks list offers options:
  • Name
  • Distance (from user)
- Map: online maps
More online maps are available.
Available in menu “Map | Online maps”.
- Map: map performance
Select quality or performance in map rendering.
Available in “Settings | Map | Rendering”.
- Map: layer selection dialog
When you tap or long press in regions with multiple markers,
the available markers are displayed to select the one pressed.
Available in “Settings | Map | Layers”.
- Map: auto hide map scale
Available in “Settings | Map | Hide map scale”.
Location animation / interpolation for smooth movement in navigation / follow.
Available in “Settings | Location | Animated location”.
GPS altitude can be read from:
  • System (may be above sea level)
  • Sensor (above sea level)
Available in “Settings | Location | Altitude”.
Speed threshold for location orientation changes.
Available in “Settings | Location | Orientation threshold”.
- App: Daytona external input device
Daytona has its own profile in “Settings | Application | External input device”.
- App: external keys
More external keys are available:
  • N: navigation (start / pause / resume)
  • F: follow location (on / off)
  • S: skip next waypoint
  • B: add bookmark
Available in “Settings | Application | External input device | Keyboard”.
- App: Italian translation
- App: Android 13 compatibility
- Various improvements
Thanks to everyone who participated in Kurviger 2.2 (Beta) program!
We’re looking forward for your feedback about the new version and we wish you a nice Kurviger experience! :motorcycle: :racing_car:
95db verbotene Straßen markieren
App: Navigation advanced route appearance
App: GPS-Höhe auf Meeresspiegel?
App: Routing history
App: Auto hide via / shaping points
Option 'Ziel' bei Routen Neuberechnung zufügen
App: Navigation icon color
App: Bookmark sort options
App: Split route
App: Online maps
App: Remember imported tracks
Speed limit display vs Font size
Problem with overwrite in export
Nach -Teilen- unterschiedliche Routen
App: Route planen mit GPS Koordinaten
App: Portuguese voice navigation
App: Location orientation threshold
App: Map performance
App: Auto hide map scale
App: Animated location
App: Distance / time in waypoints list
App: Daytona
App: Layer selection dialog
App: Scroll map to next / previous waypoint
App: Merge routes
App: Navigation actions and options
App: Different track colors
App: Navigation notifications
App: Select next waypoint to display
App: Storage access framework
Warum ist die Route anders?
Fehler beim Neuberechnen
Kurviger operation guide
Routenberechnung im WLAN JA - bei mobilen Daten NEIN
Farbige Darstellung der gefahrenen Route
Google location service
GPS recording missing when app restarts
Italian voice guidance for roundabout
Google Play error
App: Carpe Iter
Lakes rendering on multiple maps
Probleme mit Routen-Neuberechnung in der Schweiz und in Frankreich
Destination import from c:geo app not working anymore
Altitude Display on Android Phone
Offline rerouting regression (Beta)
App: Distance / time icons in waypoints list / bubbles
App: Android 13
App: GPX overlay trk + wpt
No route planning during navigation
Pro- Version nicht mehr nutzbar?
Kurviger 1 vs Kurviger 2
App: Display next waypoint
App: Colored waypoints in waypoints list
App: Charging stations
App: External keys
App: Auto hide turn instructions
Kurviger 2.2.21 is on Google Play:
Kurviger 2.2.22 is on Google Play:
Kurviger 2.2.23 is on Google Play:
Kurviger 2.2.24 is on Google Play:
Kurviger 2.2.25 is on Google Play:
(it works on offline and now online vector maps)
Kurviger 2.2.26 is on Google Play:
Everything works, no issues recognized.
Kurviger 2.2.27 is on Google Play:
1.14.27 is available, but I still don’t see 2.2.27
The updates are handled by Google, please wait until they publish them.
Läuft bei mir seit gestern.
Vielen Dank für den Support.
It is about Kurviger 2.
Sometimes Google publishes the updates within an hour, while other times it takes a few days.
I did not upgrade to the last version and now it is not available anymore on Google play:
Would it be possible to download the APK from somewhere? That would be great!
Then i will, and can hang in until the new 2.0 will arrive :wink:
