Kurviger 2.2.19 (Beta)
Kurviger 2.2.19 (Beta) is on Google Play (instructions):
- Navigation: advanced route appearance (Pro)
Display the current route section differently from the rest of the route.
Available in “Settings | Navigation | Route appearance”.
- Navigation: display next waypoint (Pro)
Display of the next waypoint is available as an optional extra panel.
Tapping the waypoint panel, the map moves briefly to the waypoint.
Available in “Settings | Navigation | Next waypoint”.
- Navigation: select next waypoint to display (Pro)
Selection of next waypoint to display is available with long press:
- Navigation: actions and options (Pro)
Available in top left navigation panel:
  • Tap: show navigation actions
    [Skip next waypoint, Avoid roadblock]
  • Long press: show navigation options
    [Rerouting, Auto zoom, Voice guidance]
- Navigation: navigation notifications (Pro)
They can be useful with external screen devices.
Available in “Settings | Navigation | Notifications”.
- Navigation: icon color (Pro)
Separate icon color settings for navigation directions (left) and app panels (right).
Available in “Settings | Navigation | Icon color”.
- Navigation: simulation improvements (Pro)
Navigation simulation is initialized at the nearest route node.
Available in “Settings | Navigation | Navigation”.
- Navigation: Portuguese voice navigation (Pro)
Available in “Settings | Voice guidance | Voice language”.
- Routing: routing history
Offline in-memory history of latest calculated routes.
Useful for “undo” in route planning and navigation.
Available in menu “Routing | History”.
- Routing: scroll map to next / previous waypoint
You can scroll the map to the next or previous waypoint with new on-screen buttons.
(works together with the crosshair function)
Available in “Waypoints” in (long press) menu of the waypoints.
Available in “Waypoints” in (long press) menu of the route.
- Routing: split route
Available in (long press) menu of the waypoints.
- Routing: merge routes
You can merge kurviger routes (files + links) using the “Extend route” option in routing import dialog.
Available in menu “Routing | Import”.
- Routing: different track colors
The import window has a color button to select the color of the imported track(s).
Available in import window of gpx / kurviger files.
- Routing: remember imported tracks
App remembers the imported (gpx, kurviger) tracks / colors when restarting the app.
- Routing: auto hide via / shaping points
You can select the zoom level where the via / shaping points appear on the map.
Available in “Settings | Routing | Via points (zoom level)”.
Available in “Settings | Routing | Shaping points (zoom level)”.
- Routing: auto hide turn instructions
You can select (or disable) the zoom level where the turn instructions appear on the map.
Available in “Settings | Routing | Zoom level of turn instructions”.
- Routing: distance / time in waypoints list
Display distance / time of waypoints in their management screen.
The same info is in the bubbles of waypoints when tapping them.
Available in menu “Routing | Waypoints”.
- Routing: colored waypoints in waypoints list
Display colored waypoints in their management screen.
- Routing: route planning with coordinates
Enter a marker with coordinates on the map for routing actions.
Available in menu “Tools | Location”.
- Bookmarks: bookmark sort options
Sort function in bookmarks list offers options:
  • Name
  • Distance (from user)
- Map: online maps
More online maps are available.
Available in menu “Map | Online maps”.
- Map: map performance
Select quality or performance in map rendering.
Available in “Settings | Map | Rendering”.
- Map: layer selection dialog
When you tap or long press in regions with multiple markers,
the available markers are displayed to select the one pressed.
Available in “Settings | Map | Layers”.
- Map: auto hide map scale
Available in “Settings | Map | Hide map scale”.
Location animation / interpolation for smooth movement in navigation / follow.
Available in “Settings | Location | Animated location”.
GPS altitude can be read from:
  • System (may be above sea level)
  • Sensor (above sea level)
Available in “Settings | Location | Altitude”.
Speed threshold for location orientation changes.
Available in “Settings | Location | Orientation threshold”.
- App: external keys
More external keys are available:
  • N: navigation (start / pause / resume)
  • F: follow location (on / off)
  • S: skip next waypoint
  • B: add bookmark
Available in “Settings | Application | External input device | Keyboard”.
- App: Italian translation
- Various improvements
We’re looking forward for your feedback about the new version and we wish you a nice Kurviger experience! :motorcycle: :racing_car:
KTM MyRide
App: Navigation notifications
App: Location orientation threshold
App: Portuguese voice navigation
Power usage
Power usage
App: Auto hide via / shaping points
App: Different track colors
Button to switch voice guidance on/off on map screen
App: Carpe Iter
App: Waypoint number in distance panel
App: Select next waypoint to display
App: Display next waypoint
Zwischenziel
Was haben nachfolgende Einstellungen für Auswirkungen?
App: Distance / time in waypoints list
Navigation multi-line panels
App: Navigation actions and options
App: Animated location
App: External keys
App: GPS-Höhe auf Meeresspiegel?
App: Auto hide map scale
App: Route planen mit GPS Koordinaten
App: Charging stations
Destination import from c:geo app not working anymore
App: Online maps
App: Bookmark sort options
Routenberechnung im WLAN JA - bei mobilen Daten NEIN
Kurviger Pro / Kurviger
App: Map performance
Lakes rendering on multiple maps
Google location service
App: Colored waypoints in waypoints list
App: Navigation simulation
App: Navigation advanced route appearance
App: External keys
App: Split route
App: Routing history
Open Topo Karten
BRouter Crashes the App
App: Layer selection dialog
App: Auto hide turn instructions
App: Scroll map to next / previous waypoint
App: Remember imported tracks
Kurviger Beta program
Strassensperre vermeiden
App: Navigation icon color
Import on Website from App: Error
Seltsame Stiländerung beim Navigation / Strange change of style in navigation
Offline rerouting regression (Beta)
Speed limit display vs Font size
Warum ist die Route anders?
Problem with overwrite in export
Nach -Teilen- unterschiedliche Routen
App: Merge routes
Open track from Kurviger pro App in kurviger.de - file is not accepted
Statt shaping points nur via points berechnen
GPS recording missing when app restarts
Skip next waypoint does not work
Kurviger 2.2.28
App: Daytona
Kurviger 2.2.2 (Beta) is on Google Play (instructions):
Kurviger 2.2.3 (Beta) is on Google Play (instructions):
Kurviger 2.2.4 (Beta) is on Google Play (instructions):
  • B: add bookmark
Kurviger 2.2.5 (Beta) is on Google Play (instructions):
A post was merged into an existing topic: App: Routing history
Kurviger 2.2.6 (Beta) is on Google Play (instructions):
Kurviger 2.2.7 (Beta) is on Google Play (instructions):
- Routing: auto hide waypoints
You can select the zoom level where the waypoints appear on the map.
Available in “Settings | Routing | Zoom level of waypoints”.
Heute mit der 2.2.7 unterwegs gewesen und alles super. Mir gefallen die neuen Farben.
Was ich immer noch so sehr vermisse, ist die Simulation im Tunnel. Es nervt wirklich, dass Kurviger nicht im Tunnel funktioniert, so wie es andere Systeme auch machen.
Thanks for the feedback.
For reports not related with the announced features,
please create new topics to discuss them separately.
This is cool :hugs:, especially when you set different zoom levels for waypoints and turn instructions.
This is something I unfortunately didn’t get how it works :woozy_face:
Can you please point it out a little more how it works?
Kurviger 2.2.8 (Beta) is on Google Play (instructions):
I was waiting patiently, but still don’t see this updated version. :pleading_face:
I do not see it, too - but it happens sometimes, that it needs a few days until I can see it - even if other users can see it already.
:thinking:
Therefore “patiently” for me means waiting one week :wink:
According to Google Play notifications, Kurviger 2.2.19 (Beta) should now be available.
not yet… am further patient :joy:
8 posts were merged into an existing topic: App power usage
Kurviger 2.2.9 (Beta) is on Google Play (instructions):
