I would like to propose a planning feature for the APP, which allows me to navigate from way-/shapingpoint to way-/shapingpoint (back and forth) and keep the zoom level at the same time. The idea is to step through all points and refine the position if needed.
At the moment one has to completely zoom out and then zoom in at each and every point only to double-check the exact location.
From my point of view two additional buttons (previous/next waypoint) should be visible only in planning mode, but not on navigation mode.
To reduce the effort, it might be sufficient to pan the map, so that the next / previous waypoint is in the center (no crosshair or something special to mark it).
For me it is not clear, which would be the next/previous waypoint, if buttons are pressed 1st. Options:
Thanks for the feedback. No - I just wanted to know if there is a setting / option which I could not found. I understand: There is no such option, and I do not want to suggest it.
Works fine, very comfortable, especially for checking all waypoints in high zoom level
Question (I did not get it): What is the function in the 2nd preview picture, and how can I get there (probably a user problem )?
It is the crosshair function, used wherever a map position is selected.
Position buttons switch with waypoint buttons until position selection.
e.g. long press on a waypoint and select “Move”
I have just seen that the “next waypoint” function zooms in to minimum zoom level in which waypoints are displayed (when started and when next/previous is tapped) - that is a very nice feature, I like it
Sorry but I still can’t find the new function “Jump to the next waypoint” I am on 2.2.7 Beta and read in the changelog description that is it available in “Waypoints” in (long press) menu of the route. Do you mean in Menu then Routing then Waypoints? There I see all my Waypoints as a text and then long press where? Where is the menu of the route?
