First of all, thank you for the great work on Kurviger. I use it mainly for motorcycle touring and I really appreciate the route planning flexibility. However, after using it extensively, I feel there are two areas that could be significantly improved.
1. Missing routing mode: “Fastest route without highways”
Currently, for each segment between two waypoints, I can choose:
Fastest Route
Fast and Curvy
Curvy Route
Extra Curvy Route
There is also a global option to avoid highways/toll roads, but that applies to the entire route.
What is missing is a very common real-world use case:
I want to reach the interesting riding area quickly, then enjoy scenic roads, and finally return home quickly again.
For example:
Home → highway allowed (reach the mountains quickly)
Mountain area → no highways, no toll roads
Return home → highway allowed again
The problem is that if I want to avoid highways on a specific segment, my only alternative is to choose Curvy or Extra Curvy. But these options are designed to maximize curves and detours, which is not always what I want.
Sometimes I simply want:
“Fastest route while avoiding highways and toll roads.”
No special search for curves, no additional detours, no motorcycle-specific optimization. Just the most efficient route using normal roads.
A practical example is crossing Switzerland to reach Airolo. I may want to avoid the motorway, but that does not mean I want Kurviger to send me on hundreds of extra curves and detours. I simply want the quickest non-motorway route.
I believe a routing mode such as:
Fastest Route (No Highways)
would solve this very common scenario.
2. Android Auto: skipping a waypoint requires too many actions
On Android Auto, the bottom-left box showing the next waypoint is very useful.
However, when selecting that box, the primary action offered is to stop navigation.
In practice, when riding a motorcycle, the most common need is not stopping navigation but skipping the next waypoint.
Today, skipping a waypoint requires navigating through multiple menus and several clicks. This is particularly inconvenient and distracting while riding, especially because many motorcycle handlebar controls are not very responsive when interacting with Android Auto.
My suggestion:
When selecting the “Next Waypoint” box, provide a direct Skip Waypoint action.
Alternatively, show both options immediately:
Skip Waypoint
Stop Navigation
This would reduce rider distraction significantly and make waypoint management much safer while on the move.
I believe both improvements would make Kurviger even more practical for long-distance motorcycle touring.
Thank you for considering these suggestions.
