The new autozoom function when leaving your current route is very useful, because I quite often disable rerouting, so the route won’t automatically be recalculated when leaving it.
But sometimes there’s a long-range detour or I simply want to vary my original route a little bit. In those cases it would be very useful, if I had a function to force rerouting manually.
I know there’s this trick with adding a via point on the street directly in front of you to trigger a rerouting, but due to my experience this can be quite fiddling some times.
So a rerouting-button would be helpful. Maybe long-pressing the navigation symbol could be a good solution, if the display shouldn’t be overloaded with buttons.
Sounds good.
Or maybe even better, an easy accessible way to switch between “automatic rerouting on” and “rerouting off”.
If you need a reroute button, you have lost your carefully planned route anyway and may want switch over to “automatic rerouting”. If you are already thinking about a context sensitive menu, that is only active when in navigation mode, such a switch might fit there.
But a bigger problem I found is that hopeless neverending rerouting in areas without internet connection.
Is it really not possible to reroute without internet connection if you have offline maps?
Yes, fine. I just wanted to add a new topic for this. Permanent re-routing is a mess, especially when no offline-re-routing is available, so switching off by default is good. But as soon as the friendly voice tells me that I have left my route, there could a button made visible to switch on automatic-rerouting. Same Button can act as a toggle to switch it back to “not re-route” again.
So witch recalculation deactivated and if an off route situation is detected, we could offer a manual rerouting option? What do others think about this?
If this is technically possible to check before, if an internet connection is available, yes, this would be good.
Or alternatively if the button is a toggle which stops the recalculation immediately, then it can just be pressed again when there is no internet connection.
The re-calculation without internet connection is really a mess as long as there is no real offline re-calculation available, it acts like an endless loop.
At a first glance I thought this is a good idea. Thinking more about it, I am not sure anymore
I am not a fan of this buttons cluttering the map.
Especially when riding off the route, I want to see as much as possible of the map.
All in all, I think a reduced menu, which is only active in navigation mode would be better. There a toggle switch automatic reroutingon off would fit perfect.
Is the “force re-calculation” no longer an issue?
What about long-pressing the GPS symbol on the right hand to force calculation? No new button, but a good ON DEMAND function which is not triggered undesired.
Thing is that everyone can come up with ideas to put extra functions on existing buttons.
So this needs careful design, where an extra menu probably can include all of them.
I definitely support the proposal of having the possibility to force the rerouting but especially for the route creation. If I have to edit the route without internet connection (e.g. in a rural area) and get internet connection later, I have to change a setting in Routing–>Optionen in order to trigger a rerouting.
I fully support this request. But this multiple use of button I don’t like.
Suggestion: when leaving the route, a sign with exclamation mark appears. Tap on sign to start recalculation would be very convenient.
