Kurviger 1.11.1 (Beta) is on Google Play (instructions):
- Navigation: simulate navigation function (Pro)
Simulate navigation anywhere with fast forward / rewind and adjustable speed.
- Play / Pause navigation simulation
- Skip previous / next turn instructions
- Select simulation speed (tap speed panel)
- Works nicely with App: Smooth movement
Available in “Settings | Navigation | Navigation mode”.
- Navigation: speed based voice guidance (Pro)
Allow speed to influence voice instructions timing (speak earlier when run).
Let’s test and see if extra fine tuning is needed.
Available in “Settings | Voice guidance | Speed”.
Fluid map move / rotate / zoom animations in navigation & follow location.
Can be used alone or together with the Kalman filter.
Available in “Settings | Location | Smooth movement”.
- Map: advanced map scale / display zoom level
Show map zoom level in (advanced) scale bar or (auto hidden) zoom buttons.
Available in “Settings | Map | Map scale”.
- Bookmarks: option to delete all bookmarks
Clear all stored bookmarks conveniently in one go (after confirmation).
Available in menu “Bookmarks | Clear”.
- Bookmarks: long press on route to add bookmarks
Add bookmarks on route via its actions dialog (long press on route).
- Stability improvements
