Kurviger 1.11 (Beta) is on Google Play (instructions):
- Location: location marker / arrow appearance options (image 1)
There have been reports, e.g. here or here, about location display problems in older devices, probably due to poor OpenGL drivers.
So I added a 2nd location appearance option available in new location settings.
It uses standard svg symbols instead of OpenGL advanced real time rendering.
It has all expected features like arrow size / tip, except (currently) custom color.
Available in “Settings | Location | Location appearance”.
- Location: show speed / altitude in follow location mode
Display speed and altitude panels also in follow location mode (besides navigation).
Available in “Settings | Location”.
- App: option to lock the touch screen (Pro) (image 2)
Useful during navigation, in rain conditions, for avoid ghosts inputs, etc.
A notification will inform for the enabled screen lock.
Then can disable the screen lock via the notification.
Available in menu “Tools | Screen lock”.
- Stability improvements
- Location optimizations for better battery efficiency
- OpenGL optimizations for performance & stability
Kurviger 1.11.1 (Beta) is on Google Play (instructions):
- Navigation: simulate navigation function (Pro) (image 3)
Simulate navigation anywhere with fast forward / rewind and adjustable speed.
- Play / Pause navigation simulation
- Skip previous / next turn instructions
- Skip to route start / end (long press)
- Select simulation speed (tap speed panel)
- Works nicely with App: Smooth movement
Available in “Settings | Navigation | Navigation mode”.
- Navigation: speed based voice guidance (Pro)
Allow speed to influence voice instructions timing (speak earlier when run).
Let’s test and see if extra fine tuning is needed.
Available in “Settings | Voice guidance | Speed”.
Fluid map move / rotate / zoom animations in navigation & follow location.
Can be used alone or together with the Kalman filter.
Available in “Settings | Location | Smooth movement”.
- Map: advanced map scale / display zoom level
Show map zoom level in (advanced) scale bar or (auto hidden) zoom buttons.
Available in “Settings | Map | Map scale”.
- Bookmarks: option to delete all bookmarks
Clear all stored bookmarks conveniently in one go (after confirmation).
Available in menu “Bookmarks | Clear”.
- Bookmarks: long press on route to add bookmarks
Add bookmarks on route via its actions dialog (long press on route).
Kurviger 1.11.2 (Beta) is on Google Play (instructions):
- Various improvements
Navigation simulation, map scale, etc.
Kurviger 1.11.3 (Beta) is on Google Play (instructions):
- Map: transparency option in color settings (image 4)
Translucent colors are available everywhere in all color settings.
Kurviger 1.11.4 (Beta) is on Google Play (instructions):
Distance based auto zoom, route color, etc.
Kurviger 1.11.6 (Beta) is on Google Play (instructions):
Simulation speeds renamed to [1x, 2x, 3x, …] as better understandable values.
Revised offline maps rendering with faster performance and better appearance.
(even with heavy countries on large resolutions with vegetation layer enabled)
Kurviger 1.11.7 (Beta) is on Google Play (instructions):
Another set of offline maps rendering improvements for even faster performance.
Kurviger 1.11.8 (Beta) is on Google Play (instructions):
- Map: add POI for accommodation, health in layers menu (Pro)
More points of interest in map layers menu for accommodation (e.g. hotels) and health care (e.g. hospitals, pharmacies).
