Kurviger 1.11.5 is on Google Play:
- Navigation: simulate navigation function (Pro)
Simulate navigation anywhere with fast forward / rewind and adjustable speed.
- Play / Pause navigation simulation
- Skip previous / next turn instructions
- Skip to route start / end (long press)
- Select simulation speed (tap speed panel)
- Works nicely with App: Smooth movement
Available in “Settings | Navigation | Navigation mode”.
- Navigation: speed based voice guidance (Pro)
Allow speed to influence voice instructions timing (speak earlier when run).
Available in “Settings | Voice guidance | Speed”.
There have been reports, e.g. here or here, about location display problems in older devices, probably due to poor OpenGL drivers.
So I added a 2nd location appearance option available in new location settings.
It uses standard svg symbols instead of OpenGL advanced real time rendering.
It has all expected features like arrow size / tip, except (currently) custom color.
Available in “Settings | Location | Location appearance”.
- Location: show speed / altitude in follow location mode
Display speed and altitude panels also in follow location mode (besides navigation).
Available in “Settings | Location”.
Fluid map move / rotate / zoom animations in navigation & follow location.
Can be used alone or together with the Kalman filter.
Available in “Settings | Location | Smooth movement”.
- Map: advanced map scale / display zoom level
Show map zoom level in (advanced) scale bar or (auto hidden) zoom buttons.
Available in “Settings | Map | Map scale”.
- Map: transparency option in color settings
Translucent colors are available everywhere in all color settings.
- Bookmarks: option to delete all bookmarks
Clear all stored bookmarks conveniently in one go (after confirmation).
Available in menu “Bookmarks | Clear”.
- Bookmarks: long press on route to add bookmarks
Add bookmarks on route via its actions dialog (long press on route).
- App: option to lock the touch screen (Pro)
Useful during navigation, in rain conditions, for avoid ghosts inputs, etc.
A notification will inform for the enabled screen lock.
Then can disable the screen lock via the notification.
Available in menu “Tools | Screen lock”.
- Various improvements
Kurviger 1.11.9 is on Google Play:
- Map: add POI for accommodation, health in layers menu (Pro)
More points of interest in map layers menu for accommodation (e.g. hotels) and health care (e.g. hospitals, pharmacies).
Kurviger 1.11.10 is on Google Play:
- Navigation: auto zoom detailed options (Pro)
Can specify in detail the fractional auto zoom levels for an enhanced navigation experience.
Available in “Settings | Navigation”.
- Stability improvements
Thanks to all who participated in Kurviger 1.11 (Beta) program! ![]()
