Kurviger 1.13.16 (Beta)
Google Play console collects reports (after submit).
Ι don’t see anything for Kurviger 1.13.11 (Beta) yet.
So what really happened can only be theories now.
Regarding combined routing services, we had discussed all that:
Internet is checked on route request, if it does not work an offline routing happens.
That’s the simplest process and will remain so. Or select offline routing in settings.
Thanks. I think it was with 1.13.10. Before last tour yesterday I had updated to 1.13.11 and had no crash on the route (also with automatic calculation active). But it is a good hint, when such things happen, I can change the route option in settings and change it back later again.
Kurviger 1.13.12 (Beta) is on Google Play (instructions):
- App: font size option
You can make the UI text on screen smaller or larger.
Available in “Settings | Application | Font size”.
- Various improvements
Available in Kurviger 1.13.16 (Beta).
Many thanks for the option to change the font size! I hope that soon we will see the option to change the size of several UI elements, although it’s probably harder to implement :slight_smile:
I noticed that the speed panel is not refreshing when following. It invariably shows one value that corresponds to the speed when activating the following function (i.e. usually 0 km/h).
During navigation is OK.
Edit: Sorry, I did not notice that @Nico_Krause has already pointed out this problem…
Thanks for the report, it will work again in next version.
Kurviger 1.13.15 (Beta) is on Google Play (instructions):
- Navigation: voice volume option (Pro)
Select voice volume in app or use system audio volume.
Available in “Settings | Voice guidance | Voice volume”.
- Navigation: prepare all audio connections to avoid cut-off instructions (Pro)
Audio connection preparation is available on all audio outputs to avoid cut-off instructions.
Available in “Settings | Voice guidance | Prepare audio connection”.
- Navigation: Danish voice navigation (Pro)
Available in “Settings | Voice guidance | Voice language”.
Really looking forward to test this one :+1:
Did you publish the beta to the play store?
I’ve joined the beta program but only seeing version 1.13.14.
Best regards,
Anders
The Beta was released on Google Play.
It may take some time until Google publish it and push it on devices.
There it was :grinning:
Will give it a go today :wink:
Thanks a lot, EMUX!
I really appreciate that:
Kurviger 1.13.16 (Beta) is on Google Play (instructions):
- App: lock screen orientation in navigation / follow
Available in “Settings | Application | Screen orientation mode”.
13 posts were merged into an existing topic: App: Lock screen orientation only during navigation / follow
