Kurviger 1: Route not found
Hello,
I am using kurvigerpro about 3 or 4 years now.
Until last week it works as it works what was normaly ok for me.
But since yesterday it stopped.
Even start and destination is in the same street i get " Route nicht gefunden " no other message.
Any idea.
BR Armin
Can you share a route example with us!
Menu | share | Route
Does your phone have Internet?
Have you installed any blocking apps?
What app version?
Where did you get the app from?
App from Google Play works properly.
Anyone still using the old Kurviger 1 should update via Google Play:
Thanks for your answer.
Unfortunatly no Route possible. Because even i put start and destination 100m in one street the answer is the same
I will check for an app blocker.
But i did not change anything from last sunday at
Version 1.14.21 and i bought it in the app store.
My Samsung s20 fe has Internet for sure .
I was travelling more than 5000km to greece without problemläs last month and on last sunday there was also no problem to navigate.
This is an old version, update the app.
(old app versions are not supported)
Updated Kurviger 1 from Google Play works properly.
Confirmed
“Route not found” with Version 1.14.21 which I have still installed for testing.
(Usually I use Kurviger Version 2.x)
After update to Kurviger 1.14.23 it works again :wink:
It suprised me, that this update seems to be necessary.
Online services are constantly changing.
Always update to the latest app version to work properly.
Thanks for your advise.
Max be iam to stupid but i can not find axway to update 1.1.14.23
Please Support me.
I supposed this but there is only version 2 which i can find. Together with the nice advertisment. Or abo.
To avoid both i bought the app once.
I can not find a version 1.14.23
If you purchased and installed Kurviger 1 from Google Play,
then the update is available on Google Play (same account).
See also
Thanks a lot for your great support and your patience.
As i wrote before…to stupid…
Now it works
Wie bei mir. Ich habe die Pro Version und da werden nun keine Routen mehr berechnet, … obwohl es als lebenslang kostenlos angepriesen wurde damals beim Kauf.
Das ist so nicht korrekt denke ich. Wie komme ich an die RoutenfĂĽhrungen?
Kurviger Pro V1.14.x wird immer noch gepflegt.
Du solltest sie (kostenlos) updaten
Siehe auch
Hi, ich nutze Kurviger Pro seit Jahren erfogreich - zuletzt vor etwa 3 Wochen. Android 9. Samsung S7. Seit vorgestern kein Routing mehr. Ich lade eine gpx-Route, sie lässt sich aber über keinen der beiden Wege mehr starten. Nach Laden der Route kommt “Route nicht gefunden”. WLAN und Funknetz sind vorhanden, Offline Karten sind verbunden. Bei Routing-Start erscheint “Kelne Route vorhanden”. Bei längerem Drücken der Positionstaste erscheint “Folge der Position” und oben rechts erscheint ein weisses Fenster mit einer km-Angabe, aber es erfolgt kein Navigation. Mit der neuen Kurviger App ist es dasselbe. Habe schon die Foren durchgeschaut, aber keine Lösung gefunden. Daher bitte ich hier um Rat. Merci.
If you mean how the app and navigation work, see:
Getting started guide:
Manual:
If you mean the route calculation, update the app:
Um den Fehler nachzuvollziehen, solltest Du das GPX hier einstellen.
Klappt die Navigation, wenn Du in der Kurviger eine einfache Route (nur Start und Ziel) eingibst?
Welche Kurviger Pro Version hast Du installiert?
  • Upload leider nicht möglich.
  • Einfache Route (z.B. DĂĽsseldorf - Köln) geht auch nicht mehr.
  • Version ist 1.13.17
