Today we updated the fastest route calculation. With the update the amount of minor roads that are included with the fastest route is reduced and the routes are better following main roads and motorways.
With this change, most of the reported routes here in the forum that contained suboptimal routes are fixed or drastically improved. That said, please give it a good test, if you find that an existing route is worse, please let us know. There might be still some things we can fine tune.
Please note: there has been no change to the different curvy routes.
Heute haben wir die Berechnung der schnellsten Route angepasst. Mit dem Update werden Hauptstraßen und Autobahnen stärker in die Planung einbezogen und ein Abfahren von diesen Straßen wird vermieden.
Im Forum gab es einige Berichte zu problematischen Routen bei Verwendung der schnellsten Route. Durch diese Änderung wurden diese Probleme entweder komplett behoben oder stark verbessert. Falls euch bei bestehenden Routen eine negative Änderung auffällt, gebt bitte Bescheid. Es kann sein, dass wir ein paar Details noch weiter optimieren können.
Bitte beachtet: Bei den kurvigen Routen hat sich keine Änderung ergeben.
Thanks a lot - the planned route through Munich has been improved a lot https://kurv.gr/3pdVZ
Before I had to put several shaping points to prevent Kurviger taking several exits of B2R just to enter B2R again
The example in Poland I posted right under your example in that thread is fixed, but yeah, your link is still weird. Maybe we should check if that street is even continuous in OSM
The situation in OSM is that the Strada Statale delle Dolomiti (highway=primary) has a speed limit of 50 km/h (which I can confirm from my GPS recording) and the nameless tertiary highway hasn’t (I don’t know if this is true or not).
But in reality taking two left turns from and back to a primary highway is most likely slower than just staying 50 meters on the 50 km/h highway, right?
