Sometimes (rarely) navigation stops working
On rare occasions navigation stops working and no recalculation is triggered any more.
This week i had a similar issue as described here but with new phone
Kurviger had navigated me to munich, then throughout the day other apps had been used.
  1. The way back home: routing | actions | turn route
  2. Start navigation (automatic recalculation on )
  3. I took another route as calculated by Kurviger.
    So virtually on every intersection through munich, a recalculation was executed.
  4. Then after 10-20 recalculations no recalculation was triggered any more.
Watch the zoom level!
Stop navigation / start navigation (position same as above)
Speed indication is still working
System settings
  • Android 8.0 Samsung Galaxy S7
  • Kalman Filter on
  • recalculate route on
  • Auto-Zoom on
    • min: 14
    • max: 16
    • off route: 15
Summary
  • independent of Android version and device (Android 8 and Android 4.3)
  • Many recalculations in a row seems to contribute.
  • not reproducible so far.
Manfred
Thanks for the report!
There, the rerouting was enabled and was not triggered?
How was internet connection, any (spoken) warning?
During all these, the screen was turned on or app was in background?
[quote=]
[/quote]
Yes, exactly. At this time navigation had been stopping working for maybe ~15min/~10Km.
Even after “stop/start navigation” no rerouting was triggered (as you can see on screenshot).
Later (at ~16:03) I stopped the app (double back) and started again.
After that the route was instantly recalculated and navigation was working again.
[quote=]
[/quote]
Screenshot says 4g :wink:
No warning I could remember of, and munich usually has excellent internet coverage.
Hmm, one thing that might be contributing:
The start point on the screenshot was the last time a successfull recalculation had been taken place.
After that I was traveling through a longer tunnel. So no GPS for some time (I think there has been a warning about missing GPS)
[quote=]
[/quote]
Screen was on and app in foreground the whole time from “point 1.” onwards.
@devemux86 just a thought:
What happens if you loose GPS signal (±) at the very moment you would detect an off route situation?
Maybe in combination with Kalman filter?
The off route detection is only triggered when getting off route significantly. So, short GPS signal loses are usually not an issue. Longer tunnels, might be detected as off-route though.
In case it’s relevant, I try to make my above answer more precise:
Screen was on and app in foreground from “point 1.” onwards of the above report.
Before “point 1.”, during the day, the app had been “running” in the background most likely (navigation off).
Manfred
Ich hatte gelegentlich das gleiche Problem. Manchmal stoppte kurviger pro während der Fahrt. Fast immer nach Pausen, wenn also GPS abgeschaltet wurde, um Strom zu sparen. Man kann es sehen, weil keine nächste Abbiegung mehr angezeigt wird etc. Da hilft nur noch Beenden der app und Neustart, dann geht alles wieder.
I occasionally had the same problem. Sometimes kurviger pro stopped while driving. Often after breaks when GPS has been turned off to save power. You can see it, because no next turn is displayed, etc. You have to quit the app and restart, then everything works again.
Thanks for the feedback,
Can you describe that workflow, how GPS is turned off?
By user or battery optimization, app is still active or in background?
Okay, ich habe es jetzt noch einmal ausprobiert. Das Problem kommt, wenn ich GPS ausschalte. Nach dem erneuten Einschalten von GPS wird die Route zwar noch angezeigt aber nicht mehr berechnet. Die Abbiegeinformationen fehlen, siehe Bild. Es findet keine Routenansage mehr statt.
Ich muss die App beenden und neu starten. Dann geht alles wieder
Okay, I tried it again. The problem comes when I turn off GPS. After switching GPS on again, the route is still displayed but no longer calculated. The turn information is missing, see picture. There is no more route announcement.
I have to quit and restart the app. Then everything works again.
I have also had this problem sometimes. It does seem like it looses GPS in an area when it happens, maybe too many trees for a clear signal.
I can not find anything in which my phone shuts down GPS to save power and have no apps to do this. A riding friend has same problem on same ride and seems to happen to him at same times. I am thinking this app gives up or gets hung when it can’t get a GPS response for a while.
Do you both use the Kurviger Pro app and at more or less the same time the app doesn’t recognize that you are on the route? It would be interesting if you could provide a case that provides an option to reproduce this situation. So far this issue has been non reproducible and seems to occur very seldom.
Both use Kurviger Pro and we both updated it sometime this year to the newest version.
Yesterday, only my friend had the issue, but it may have been caused by all of the following together at same time:
  1. loss of GPS
  2. Getting too far off route and need to recalculate. (He took a wider turn onto another road then I did, Kurviger wanted to recalculate for him, navigation hung. Mine did not recalculate and was fine)
  3. May or may not have and internet connection at the time.
We ride on back roads and on some routes, the Kurviger route does not track with the road and could be off 10-20 feet from the road or more. Been slowly fixing them on OpenStreets.
Today I had the same problem: after taking another way than the original route was planned (due to upcoming rain I wanted to be home soon) I triggered a recalculation of the route. A new route was shown and I also had a GPS signal, but no turn instructions any more. Even after switching between navigation and follow mode or triggering another recalculation.
I made this screenshot after returning home:
I’m pretty sure I manually triggered the first recalcution of the route in an area where I have no data connection. Maybe this could be the reason for the problems with the missing instructions.
Please create new topics to make reports.
This thread has reports for very old app versions, so mostly it’s irrelevant to present.
Then nothing should happen or will repeat rerouting later (if enabled).
The whole thing with online routing issues is really frustrating, isn’t it?
Let’s see how offline routing can improve many of these corner cases.
