Stick to Mainroads in Villages
Also, moving the (redundant) waypoint slightly will have an impact on the route, as you can see here:
https://kurv.gr/MZRES
Thanks a lot! It usually takes up to two weeks for a data update to be reflected in the routing.
Mhm I think in this area something weird might be going on. I need to check this case a bit closer. Let’s see what changes after your data changes become active.
This seems to be fixed now. Thanks.
