Transfer of avoid options
Ah ok, thank you.
I’ve tested it with a unpaved tour: (Enzianhütte, Zirog, Brennerbad):
This looks woderful. I was never aware that there is a brown line for unpaved road.
Unfortunately it’s still not visible in the App. I’ve transferred this testroute to the App Pro and there it’s not marked.
Do you know if this change is also coming?
The reason is that on tour, using the App it should be visible concerning the offraod part, distance etc.
Another problem:
After importing exactly this route to App Pro-Version ALL options are marked, even “not using small roads”, “not using unpaved roads” “no main roads” - completely alle possibilities!?
Last sunday I had the same, but thought that I’ve changed my options in the App. (Importing QR-code from web tourer to App Pro). Actually it was the same. Options like mentioned in the picture, marked everything in the App.
Transferring the route from App Pro to a second mobile (App Pro) did not show this failure. What’s that?
Thanks in advance
BR juschka
Strength of avoidances will come in the app in the future:
When you transfer routes in the app and want to keep the website subscription options,
you should use the (offline) *.kurviger file format (to avoid route recalculation).
When making reports, please attach the kurviger files, so that everyone can verify the reports.
I’ ve used the kurviger format, but the in the web included information about unpaved roads ( brown line, additional text) is not yet existent in the App Pro?
Br juschka
Juschka, please attach your file or the URL.
You want help, then please provide, what you are asked for.
Nobody asked for something like that.
There is no guarantee that it will look / work like the website.
The colors in the app are used for the multiple route profiles.
URL (https://kurv.gr/JFDPr) and file (Innsbruck - Brenner.kurviger (6.9 KB) ) are easy to create from the screenshot. :woozy_face:
Whereby the last kilometers shown there remain identical with every setting - there is only this one way! :roll_eyes:
And of course URL / File differ in kurvigerPRO:
Only when using the .kurviger file (the left screenshot), the route in the app corresponds exactly to the route in the WEB, because
Sorry guys, but we’re discussion different things - and again - as others mentioned before - it’s not the easiest one to explain something in english.
  1. the route with unpaved road:
@ I know Walter - I’m here in the forum since several years. The file is not relevant.
The screenshot is only an example, it’s not relevant if we’re discussing of the the Brennerbad - Enzianhütte or other trips.
https://kurv.gr/Dx6g7
The question was if this information we get on the web-version will be visible in future in the App. Everywhere and every anpaved (legal) road, nevertheless of the country.
If it is not marked as a brown line then any other colour or pointed or whatever - to identifiy this change of street quality?
  1. I have used the kurviger file for export from web to App - and @devemux86 the information of the web-route is not identically imported in the App-version as shown in the screenshot. So it’s to easy to shorten your answer - I’m using kurviger since first trial version I know how to use the kurviger-file-format.
    In the APP all options are changed while importing and everything is marked, even if I don’t have it marked in the web-version and while export / share files… You’ll see it in the screenshots.
Patrick above has mentioned principally the same. That was the reason I continued this existent discussioon. To get the information also in the App.
And for sure I thinks that’s normal, that a development on the website with new features should be available in a similar way. If I’m planning specially things on the website (with great support features for this), then it’s normal that you also would like to drive it in reality with the APP?
And what’s the procedure if you have to plan while driving the trip with the mobile + App - unfortunately it’s actually not possible to identify the classification of the road.
For sure it’s normal that the development is not in parallel between App und Website. Sometimes the App is earlier with new things, sometimes the website - but I think your comment that nobody is expecting (between a defned time slot) this is not correct.
BR juschka
Different platforms - different development - different implementations…
There are no defined time slots and estimate times of arrival for features.
You ask for something and wait patiently for a (possible) implementation.
No, screenshots alone are never enough in the reports.
For website subscription reports you must also attach the kurviger files.
(not everyone has a subscription to the website, so the urls do not work)
https://forum.kurviger.com/t/avoid-paved-roads/2073/10
@juschka10001 : Das Kurviger File dient meiner Meinung nach nicht dazu, zu überprüfen, ob Du alles richtig gemacht hast, sondern dazu, ggf. einen Fehler / ein Verhalten der App nachzustellen.
@devemux kann nicht bei jeder Rückmeldung mühevoll versuchen, den Fehler durch Rumprobieren zu reproduzieren, sondern ist darauf angewiesen, einen gefundenen Effekt schnell nachstellen zu können.
Da viele Effekte nur in ganz speziellen Konstellationen auftreten, solltest Du einen Problemfall durch bereitstellen von möglichst viel Information in kompakter Form beschreiben, das wäre meiner Meinung nach in dem Fall:
  • ein Export Deiner Kurviger Einstellungen aus der App vor dem Import des Kurviger Files
  • das entsprechende Kurviger File
  • ggf. ein Export der Deiner Kurviger Einstellungen aus der App nach dem Import des Kurviger Files
Aber ich habe doch den file bzw. den Kurzlink ergänzt?
Und ergänzend den screenshot wie die Einstellung im Web war und wie es dann auf der App landet.
Was soll ich denn noch machen?
Ich persönlich kann nichts dafür, dass jetzt seit neuestem offensichtlich beim Transfer von der Homepage auf die App Daten oder Einstellungen geändert werden, obwohl ich das *kurviger-Format nutze.
Es hilft doch keinem, wenn dann nur die Ansage kommt, halt das Kurviger-format zu nutzen. Das mache ich seitdem es das Format gibt und es klappte sehr gut.
Letztes Jahr hat das also noch komplett funktioniert, also muss es jetzt mit den letzten Änderungen von Web oder APP zu tun haben - ich weiss es nicht welches von beiden, aber so ist es leider sch…
Auch heute hatte ich wieder das gleiche Problem.
Route auf der Homepage geplant, per Kurzlink und QR-Scan im kurviger Format auf das Handy übertragen. Dort waren wieder alle Häkchen bei den Optionen aktiviert (wie im Screenshot). Wenn ich dann die Einstellungen manuell nacharbeite, wie ich es eigentlich auf der Webpage hatte (also wieder Haken raus bei Schnellstrasse, Hauptstrasse, Mautstrasse etc.) - dann zeigt er eine komplett andere Route an, als ich geplant hatte. Wir sind heute 50km doofe Hauptstrasse gefahren obwohl ich gestern im Web die Nebenstrassen geplant hatte. Natürlich kann ich Routen manuell nacharbeiten, wenn ich zufällig die Gegend kenne, aber im Urlaub fällt mir das nicht auf auf fremden Strassen, dass er plötzlich auf potzlangweilige Strassen ändert. Und damit brauche ich weder auf der Webpage planen noch die Route transferieren aufs Handy, wenn danach ganz was anderes rauskommt. Der ganze gute Prozedere ist dahin. So macht das leider keinen Spass mehr
VG
juschka
Regarding your above route url:
  • It displays “Your route contains exclusive Kurviger Tourer features”.
    So cannot examine it, as not everyone has a website subscription.
  • But it has all avoid options selected, so app will have all of them too.
Short links / QR codes recalculate routes (with app supported features).
Kurviger files are better as they always transfer offline the original route.
Ja, genau dann passiert es.
Wenn du mit der Tourer Webseite eine *.kurviger Datei erzeugst, diese auf dein Handy überträgst und dann in die APP importierst… dann werden alle Einstellungen wie auf der Webseite übertragen.
Web Tourer und QR bzw. Link geht “bisher” nur unter Verlust der Tourerfeatures.
Sorry, ich kapiere es einfach nicht.
Also wenn ich auf der Homepage eine Tour plane (inzwischen mit dem Tourer-Abo), dann stelle ich einige Feinheiten ein (kein Maut , keine unbefestigten Wege usw.).
Es entsteht eine tolle Tour, die auch genauso ausschauen soll.
Die “Grundfunktionen” der Haken für die Strassen, Maut, Fähre etc. hatten wir ja in den letzten Jahren auch schon!
Vor der Tourerfunktion (die ich übrigens toll finde) hat man dann die Route per kurviger-Dateiformat aufs Handy (App Pro) übertragen und hatte EXAKT diese Tour, keine Neuberechnung und absolut keine Änderung. Perfekt auch fürs offline-routing.
Das war auch immer die hier vorgeschlagene Vorgehensweise wenn es Probleme gab mit unterschiedlichen Routen.
Jetzt seitdem es die (tolle) Tourerfunktion auf der Webpage gibt, heisst es ich kann einstellen, was ich will und ich kann diese Tour nicht identisch auf das Handy übertragen, weil eben ALLE Einstellungen zerschossen sind? Oder gibt es eine andere Vorgehensweise - nicht mehr das kurviger-Format nutzen, sondern doch wieder gpx?
Da ich die Route absolut identisch auf zwei Handys bringen muss, bin ich darauf angewiesen, dass die Route bei Export/Import so bleibt wie geplant, sonst verschiebt es sich beim einen irgendwohin und beim zweiten woanders. Damit kann man nicht abfahren, das ist ja blöd.
Ich hatte bei der Einführung des Tourerabos verstanden, dass die “Feineinstellungen” wie “keine Mautstrasse” auf jeden Fall bleiben würde im Transfer mit den kurviger-Einstellungen. Ich hätte nicht gedacht, dass als Grundeinstellung in der App dann rauskommt “vermeide alles was geht” - was ja auch Blödsinn ist: wenn man per App-Einstellung Hauptstrasse, Maut, Schnellstrasse, kleinste Strassen und unbefestigte Wege vermeidet…was soll man dann noch fahren?
Also ist die Lösung das Tourerabo auf der Webpage wieder rauszuwerfen?
VG juschka
Ok Korrektur, ich habe es gerade ausprobiert - es liegt nicht an der Tourer-Version der Homepage:
Auf der Homepage habe ich mich vom Tourerabo abgemeldet.
Route erstellt wie “früher” - exportiert mit kurviger-Format, Kurz-Link
und importiert ohne Änderungen auf das Handy (App Pro)
Und es sind wieder alle Häkchen bei den Optionen in der App markiert, wie bei meinem Screenshot ganz oben, also “Vermeide quasi alles”
Also am Tourerabo liegt es nicht, da bin ich abgemeldet. Funktionen des Tourerabos gehen auch nicht, habe ich bewusst ausprobiert
Handy ist Android, neueste Version, Kurviger App ist auch aktuell.
@boldtrn
Irgendwas stimmt nicht an Eurer kurviger-QR-Link-Erstellung, entweder auf Homepageseite oder auf Appseite!
Viele Grüsse
juschka
Opening your route url, the website shows ALL avoid options selected.
  • additional_weighting=avoid_edges
  • avoid_toll_roads=true
  • avoid_ferries=true
  • avoid_motorways=true
  • avoid_main_roads=true
  • avoid_small_roads=true
  • avoid_unpaved_roads=true
Why do you expect the app to display them differently?
The discussion about the transfer of the avoid options was moved to its own topic.
Wenn Du die Route per *.kurviger Datei überträgst, dann ist der QR-Link doch völlig egal!
Also Route exportieren und auf dein Smartphone übertragen.
z.B. per USB oder alternativ auch Google Cloud oder ähnliches.
… Wie auf der Webseite auch
Sieht das bei Dir anders aus?
Teilen der Route im forum per Kurzlink oder QR-Code des Designs ist für Nicht-Tourer-Benutzer von geringen Nutzen, da diese weder bearbeitet noch in original design exportiert werden können!
Als Tourer-Benutzer fügen Sie am besten NUR das .kurviger-Datei hinzu, um es im Forum zu teilen. Es kann so auch für Nicht-Tourer-Benutzer in der KURVIGER-App per direct verwendet werden. Die Tatsache, dass Nicht-Tourer die Extras nicht bearbeiten können, ist verständlich, aber dass Sie das Original nicht einmal als Datei herunterladen können, ist ärgerlich einschränkend und führt teilweise zu dieser Diskussion.
Wichtig! Auch als Tourer-Benutzer NUR der .kurviger-Daten exportieren, um sie in Ihre eigene KURVIGER-APP zu benutzen. Kurz Link oder QR-Code funktioniert nicht mit dem erwarteten Ergebnis. Auch als tourer können sie die datei nur so nehmen, wie er ist. In der aktuellen mobilen App selbst, ist keinen Spielraum für typical tourer änderungen danach. (Ein tourer gebraucher soll dass mal bestätigen)
Ich (nicht tourer) verstehe es so es bleibt momentan nur dann der umweg uber die website.
Und ja, mit der Tourer-extras wurde alles so etwas extra verwirrend(er).
The discussion is not even about the website subscription.
The report states that the avoid options may change when the website exports a route,
that is then inserted into the application.
But this cannot be verified: the reported route urls have selected ALL avoid options!
