[Der deutsche Text kommt weiter unten]
The initial design of the Kurviger website has been created over 5 years ago. Ever since new features were added, and the UI was slowly filled with buttons and options to continuously add and refine features. Therefore it was time to rethink the design, to fit all the new features that were added over the years, but also to have enough room for future features.
I am really excited to show you the new design.
What you can see at first sight:
- There is now a navigation bar on the top
- There are a lot less buttons in the sidebar
The new UI concept is that the sidebar can change it’s content based on what you are doing right now.
So for example when you are searching for a city in the waypoint search, the sidebar switches to a search widget:
You can always go back by clicking the “back arrow” on the top left or by pressing ESC. The waypoint search is just one example, but all of these “context based widgets” are close like that.
Less frequently used buttons have been moved into the route dropdown:
The Kurviger Cloud area was completely revamped to make it easier to use, and make many things easier, like exporting your favorites as GPX or to sort the list to your liking:
The import view was combined with tourcodes and the export view was combined with the share url feature:
To switch between these more important views in the sidebar you can use the navigation bar. That way we got rid of almost all popup windows. This allows you to still work on the map while importing or exporting.
That’s just a few of the bigger changes, essentially every UI has been updated and improved where it made sense.
Since this is a huge change, probably not everything is perfect yet. So if you have any feedback, ideas for improvements or find an issue, please let us know.
Das originale Design der Kurviger Webseite wurde vor über 5 Jahren erstell. Seit dem sind kontinuierlich neue Funktionen hinzugefügt und verfeinert worden, dadurch wurden auch stetig neue Knöpfe und Optionen hinzugefügt. Deshalb war es an der Zeit die UI komplett zu überarbeiten um Platz auf der Oberfläche zu schaffen und um genug Platz für neue Funktionen zu haben.
Ich bin richtig gespannt darauf euch das neue Design zu zeigen.
Auf den ersten Blick sieht man:
- Es gibt eine Navigationsleiste Oben
- Es sind deutlich weniger Elemente in der Seitenleiste als vorher
Das neue Konzept ist, dass sich der Inhalt der Seitenleiste ändern kann, je nachdem woran du gerade arbeitest.
Wenn du zum Beispiel nach einem Wegpunkt suchst, dann wird in der Seitenleiste ein Such-Widget angezeigt:
Du kannst jederzeit aus diesen Widgets zurückspringen indem du Oben-Links auf den Zurückpfeil drückst oder die ESC-Taste drückst.
Weniger häufig verwendete Funktionen wurden in das Routen-Dropdown verschoben:
Die Kurviger Cloud wurde grundlegend überarbeitet und ist jetzt noch einfacher zu bedienen. Zusätzlich wurden einige neue Funktionen eingebaut, wie z.B. der Export von Favoriten oder die Sortierung der Liste:
Der Import wurde mit den Tourcodes kombiniert. Der Export enthält nun auch die Teilen Funktion:
Um zwischen diesen wichtigeren Ansichten zu wechseln kannst du die Navigationsleiste Oben verwenden. Dadurch sind wir fast alle Popup Fenster aus Kurviger entfernen. Dadurch kannst du z.B. beim Import oder Export parallel noch die Karte bearbeiten.
Das sind jetzt nur einige der größeren Änderungen. Im Grund wurde jede Ansicht überarbeite und Verbesserungen eingepflegt wo es Sinn macht.
Das ist eine Riesen-Änderung und vermutlich ist noch nicht alles perfekt. Falls du also Feedback hast Ideen für Verbesserungen, oder einen Fehler gefunden hast, melde dich bitte.
