Do you find useful in your travels a function for pause / resume navigation?
With pause navigation halts at last state and need to resume it anywhere / anytime to continue.
(idea comes from that discussion)
This could help with strict navigation. Resume would introduce the same issues as with flexible navigation?
A big benefit would be for strict navigation.
What issues do you mean with flexible navigation?
It’s not about resume route. But freeze navigation calculations, so navigation pauses at last state.
When be ready to resume driving again, either on route or anywhere else, can resume navigation.
I didn’t really miss it, but I’d appreciate it.
Not at the gas station, but on longer lasting stops for sightseeing or coffeebreaks.
Nein, finde ich nicht nĂĽtzlich.
Das wäre eine unnötige Funktionserweiterung.
Sorry I don’t get you. In what situation the “long press” should happen?
Pause of navigation can only happen when it has already started.
Resume of navigation can only happen when it has already paused.
Similarly to how music / video players work - so more like your (1).
So when navigation runs, can long press its button and pause it.
Navigation freezes and sometime later can resume it via button.
I’ll think for UI & button, more important now is if we need the pause / resume function.
I don’t think that a “pause / resume function” is needed for flexible navigation.
With flexible navigation you can simply start navigation anywhere on the route, and you are done.
This maybe different with strict navigation.
I think, currently we have too few people who have actually tested strict navigation.
That parts of the route are skipped unintentionally. When I resume the navigation, the same could also happen?
To me this sounds like we are making strict navigation flexible again
Absolutely. I had already asked for such a function at least 2 years ago. But as Robin says I would not like to make the strict navigation flexible again with it. Pausing navigation makes especially sense to me if we have a tour summary at the end of the tour with overall length and duration, pure journey or running time, duration of the break time, average speed including breaks and without breaks, maximum speed (all in km/h, not m/s; or other regional values depending on the settings),
Das kannst du alles aus dem mitlaufenden GPS-Track auslesen.
Pause / resume in flexible navigation seems unneeded, as can exit / enter route anywhere.
It could be useful in strict navigation to cover stops, as strict route following mandates that:
“Navigate along the route without shortcuts, i.e. follow the route strictly from one waypoint to another. When go off route, the rerouting tries to resume to the last omitted waypoint.”
That is irrelevant to this feature’s purpose. It was proposed / discussed elsewhere in forum:
No, like mentioned above it is not related to resume route.
Pause / resume navigation is different, while strict mode remains active:
Perhaps all these are complicated and not much useful to average user?
A post was split to a new topic: Auto start navigation
Continuing the discussion from Routing issue with option "strict navigation":
Just an idea for a possible user interface for pause / resume:
If implemented, the navigation would then have 3 states.
Let the user be aware of the 3 states.
Maybe by changing the color of the navigation button. e.g.
What if pause / resume would be the default behavior? ![]()
The disadvantage would be, that this would change the behavior for all users.
But would it hurt?
I don’t think, that it would make a practical difference for flexible navigation.
Flexible navigation would continue seamless, regardless if it has been paused before, or is starting fresh. ![]()
But it would be a win for strict navigation, to be able to continue after a break.
Thanks for the ideas.
Anyway I still haven’t thought much the workflow or the appearance, as implementation and maintenance are also important for me for any new feature.
Introducing a state machine is a very good idea ! This will finally make it possible to distinguish between the first start (after the route was loaded and/or changed) from a pause. Question is what transitions will lead to the paused state. You could try:
Conversely, the transition from paused to running:
I think that this would allow for a great improvement of the user experience.
Thanks for the detailed thoughts!
Looks like a nice intuitive workflow, that also protects navigation from accidental touches.
Also the more frequent actions belong in tap & the more rare actions belong in long press.
(similar to how the location button works)
Indeed that would also change slightly current workflow. ![]()
Anyway nothing in app is set in stone!
How pause / continue navigation works in other navigators?
In Calimoto there is a Pause/Resume Button, pausing shows the overview mode without stopping the tour
In TomTom Go there is an arrow for switching between the Overview/Planning Mode without stopping the tour (tour can only be stopped via menu actual route → stop route)
In Navigon Cruiser you tap and swipe to the right, then you have an own GUI site with big easy to use (also with gloves) squares with own functionality for example “insert new wp”, “skip road blocking” “skip next waypoint”, “pause/resume navigation”, “pause/resume recording”, “show complete route”, “stop route”, “planning mode”, “WOW button for automatic storing of beautiful locations or roadways”, “voice output”, “Glympse”, “save location”, “map view”, … these direct funktions are configurable by the user (max. 6 per site).
Navigon Cruisers method is the best fail safe mode to my point of view because it prevents operating errors.
Pausing automatically based on Zero speed for more than 15 secs for example sounds also to be a nice feature.
The Wow button is placed in the middle of the bottom
Wenn pressing while driving, you have the option to automatically save
This is exactly what I have also posted here and this is inuitive for my point of view :
Additionally with temporary fail safe handling via local files (if technically possible and not too complicated to develop).
