Kurviger 1.13.17 is on Google Play:
You can set waypoint names inside the app via:
- Menu (long press on waypoints)
- List (menu Routing | Waypoints)
Waypoint names are used in navigation, with bookmarks / search and routes (kurviger, gpx, itn, mpjs).
You can set waypoint types (regular or shaping) inside the app via:
Shaping points are any position along a route that will not alert you when you arrive.
- Navigation: pause / continue navigation (Pro)
Tap navigation button to start and then pause / continue navigation.
Long press navigation button to stop a started or paused navigation.
- Navigation: strict route following (Pro)
Navigate along the route without shortcuts, i.e. follow the route strictly from one waypoint to another. When go off route, the rerouting tries to resume to the last omitted waypoint.
Available in āSettings | Navigation | Rerouting modeā.
- Navigation: map orientation modes (tap compass) (Pro)
Available map orientation modes in navigation:
- No rotation
- Movement direction 2D
- Movement direction 3D
- Route overview
Available when tap compass and in āSettings | Navigation | Map orientationā
- Navigation: change display color (Pro)
Support different colors + transparency for navigation display.
Available in āSettings | Application | Display colorā.
- Navigation: turn instruction display option (Pro)
You can show / hide turn instruction display panel in navigation.
Available in āSettings | Navigation | Show turn instructionsā.
- Navigation: voice volume option (Pro)
Select voice volume in app or use system audio volume.
Available in āSettings | Voice guidance | Voice volumeā.
- Navigation: prepare all audio connections to avoid cut-off instructions (Pro)
Audio connection preparation is available on all audio outputs to avoid cut-off instructions.
Available in āSettings | Voice guidance | Prepare audio connectionā.
- Navigation: Danish voice navigation (Pro)
Available in āSettings | Voice guidance | Voice languageā.
- Navigation: improve rerouting settings (Pro)
- Navigation: improve rerouting at start (Pro)
- Navigation: improve BRouter turn instructions (Pro)
- Export: GPX (offline) format (with waypoint names)
For convenience you can export routes in GPX format also offline (with waypoint names).
- App: lock screen orientation in navigation / follow
Available in āSettings | Application | Screen orientation modeā.
- App: external input devices (WunderLINQ, etc.) (Pro)
Support external input devices, like keyboard, WunderLINQ, etc.
Available in āSettings | Application | External input deviceā.
You can make the UI text on screen smaller or larger.
Available in āSettings | Application | Font sizeā.
- Map: add POI for parking in layers menu (Pro)
More points of interest in map layers menu for parking areas.
- Map: option to group markers
By clustering the markers, we can put a large number of markers on the map without making the map hard to read and hurting app performance.
Available in āSettings | Map | Maximum zoom level of marker groupsā for bookmarks, GPX, etc.
- Various improvements
Thanks to all who participated in Kurviger 1.13 (Beta) program! ![]()
Weāre looking forward for your feedback about the new version and we wish you a nice Kurviger experience!
