back to route / closed road
hello.
during my last rideouts following “problem” occurs, in case I cannot follow the planned route/track:
  • standing at a crossing with e.g. left turn road is closed to me it´s not clear using “closed road” buttom…
    • which road will be “closed” - current or next turn?
    • will I be rerouted to the next possible “back to route”?
  • in case I do not use “closed route” but “Neuberechnen”, which rules are valid for “Neuberechnen”?
    • especially: will I be routed next opportunity to ride on original planned route?
    • or will kurviger-app start a complete new calculation, based on which parameters?
BR
Markus
That is your decision :slight_smile:
After you click the “closer road” button, you can chose the distance the closure starts.
The blocked part is shown on the map as a red line.
“Neuberechen” routes you to the next unvisited waypoint, which may be the original route.
It may guide you back to the point where you have left the route.
“Neuberechen” does not take into account, that some part of the route is blocked.
There is a (very long) thread about the behavior.
