Integration of charging points
I’m riding an electric motorcycle (Zero SR/F). Instead of fuel stations I need charging points. Is it possible to integrate those?
Chargemap gives - in my oppinion - the best information and most possibilities for filtering:
I know, I’m sort of an exotic example. However - It will go fast with new electric motorcycles in the future …
Seems like the amenity=charging_station tag in OpenStreetMap database.
Yes, that’s it!
Chargemap gives better/more information; however this [amenity=charging_station] tag would be a huge improvement.
Please allow me to revive the topic.
I’m still eager to get charging points into kurviger.de .
I just signed for the Tourer abo, as I plan to use kurviger.de despite my Garmin zümo XT and BaseCamp.
A really good open source for charging points I found meanwhile is
From there it is possible to download charging points in form of *.gpx-Files. Look for 'Stromtankstellen POI.
You can filter for what you need exactly.
I was able to integrate it into my XT for POIs on the way (entlang der Route). This is fine if I’m on the bike but does not help much if I’m planning a big tour.
I’d very much appreciate it if kurviger.de could give this information. For electric motorcycle this information is even more important than fuel stations for ice-bikes.
You can load GPX files as overlay when planning a route, have you tried that?
Thanks for the tip. I have tried after you gave the tip. It worked for Switzerland although it slowed the website down. As there were too many charging points it was not usable in Germany, not speaking of whole Europe.
Meanwhile I found a way to implement the charging points into BaseCamp but I have to update the transfer from time to time as charging points are growing fast.
At the moment I do a first rough planning in Kurviger Tourer, then I change to BaseCamp.
As I prefer to plan in Kurviger Tourer my wish regarding the charging points upholds.
My source for charging points meanwhile has changed to goingelectric.
I’m not quite sure but it may be Kurviger could use that source also.
Yes, I’m completely aware that electric motorcycle drivers are view.
But I’m completely sure that it won’t take long and we are many more.
The faster Kurviger is in that point, the greater the advantage ‘in the market’ will be.
The big issue with sources from other websites is usually that their license does not allow their data to be used. So if the source is not OSM, it can be complicated to include them as this would require some sort of licensing agreement.
You request is not forgotten :slight_smile: - maybe we can find a way to integrate this in the future :+1:
I’m no technitian or software ingenieur.
However, I guess this is the website which may help you answer some questions regarding usage and licencing: " API zum Stromtankstellenverzeichnis"
I’m aware that this will not be integrated in the near future. But I wanted it to be kept ‘warm’.
Haven’t seen the API information, thanks for sharing :+1:
Looking at OpenAndroMaps offline maps, their tag-mapping and map style
are supposed to include the amenity=charging_station OpenStreetMap tag.
Meanwhile the feature to display charging stations is implemented:
But you can also create a GPX with the OSM data to get an clickable overlay in the app:
  • go to this overpass turbo search
  • zoom the map to your desired area (do not set it too large, might cause an timeout)
  • press “RUN”
  • press “Export” and select “download as GPX” (click on “download”!)
  • load downloaded “export.gpx” as overlay in Kurviger app
  • via long tap on icons you can add charging stations as waypoint:
I’m still waiting / hoping, that the charging points can be chosen to be shown via POIs on the website …
What is the status on this?
You can use the way via overpass turbo described above also for website.
We are looking into adding more POIs in the future, there is no short-term road map for this, but it’s planned.
Thanks for the tipp.
However: As far as I understand this works as ‘gpx-Overlay’.
As you can see in my post 'Sep ‘21’ I tried that already - the source of the data there being ‘goingelectric’.
Problem: Too much data slowed the website heavily to a degree it was not usable anymore.
I use Kurviger for my route planing with an ICE bike but I also plan routes for a group with a couple of Electric bikes in it.
On the map I can see the petrol stations but is there a way to get the charge stations as an optional layer as well?
It would make planning a route a lot easier. Now I have to use chargemap as well and switch between this and kurviger. On the road with add hoc planning it’s even more complicated.
thanks
Anton
I moved your request to an existing discussion. You also have the option to integrate them as overlays, for example here you can find a post with charging stations for Germany that you can integrate as Overlays in Kurviger: [BETA] OverlayManager - manage your map overlays | Verwalte deine Overlays - #11 by Sigi_BY
In the future we plan to better integrate charging stations into Kurviger as well.
Thanks! This makes life a bit easier :slight_smile:
It’s now possible to search for charging stations, see: Search along Route or in Area | Suche entlang der Route oder in einem Bereich
Hello, as I am riding e-Bike ( Energica) I would love if you could integrate charging stations into the POI
