Add amenity=charging_station in map layers.
Looking at OpenAndroMaps offline maps, their tag-mapping and map style
are supposed to include the amenity=charging_station OpenStreetMap tag.
wow that was quick
2 posts were split to a new topic: Kurviger 2 subscription
I really understand the need to show the charging stations, but wouldn’t it be possible to single them out as a separate, optional category that can be hidden? Or at least change the color of the icon (probably the easiest solution)!
I expect 99,9% of motorcyclists are not interested in them but the icon is almost identical to the gas station so it can be misleading.
I agree, so I made a small modification: App: External map styles - #16 by rumbrummer
I will put fuel + charging stations into separate layers in the next app update.
(usually they are needed / activated separately)
Guter Plan!
Sonst ist mancherorts alles zugemüllt mit irgendwelchen Ladestationen (z.T. für E-Bikes)die man eigentlich nicht wirklich braucht…
Works well thanks!
I is a very good solution to put the fuel and charging station into different layer because it’s an either / or decision.
As one of the earlier users of kurviger pro I still use the “old” 1.14.21 version of kurviger.
Is it intended to include the different layers for the users of this version?
Best regards,
Michael
Development continues in Kurviger 2.
Kurviger 1 is in maintenance mode.
Kurviger 1 could sometimes get internal improvements, as both use the same Cruiser libraries.
