Kurviger 2.1.11 is on Google Play:
- Routing: straight line route profile (Pro)
It is now possible to connect sections of the route with a straight line.
You can change the profile color in “Settings | Routing | Straight line”.
Navigation with straight lines works if you turn off automatic rerouting.
- Navigation: screen saver in navigation / follow (Pro)
Navigation / follow have a screen saver: the app display turns black.
(works best with dark theme and fullscreen mode)
The screen turns on at voice instructions, before turns, when be off route and touch the screen.
Available in “Settings | Navigation | Screen saver”.
- Navigation: strict route following (Pro)
Navigate along the route without shortcuts or optimization.
Available as checkbox in “Settings | Navigation | Strict route following”.
- Navigation: text-to-speech processing (Pro)
You can enable a pre-processing of text-to-speech instructions.
(it may be useful for engines other than Google text-to-speech)
Available in “Settings | Voice guidance | Text-to-speech”.
- Tools: GPS recording dialog (Pro)
Also available in menu “Tools | GPS recording”.
- Map: disable follow location
Follow location can be disabled when long press the location button.
- Map: charging stations in map layers (Pro)
It requires new offline maps.
Available in menu “Map | Map layers”.
You can turn on / off the icon and font outlines in the display panels.
Available in “Settings | Application | Outline”.
- App: Carpe Iter external input device
Carpe Iter has its own profile in “Settings | Application | External input device”.
- App: WunderLINQ zoom or move
You can select zoom or move for WunderLINQ in “Settings | Application | External input device”.
- App: Android 12 compatibility
- Various improvements
Thanks to everyone who participated in Kurviger 2.1 (Beta) program!
