Kurviger 1.1.19 is on Google Play:
- Map: (optionally) rotate location arrow at tip instead of center (Pro)
Location direction arrow can now be rotated also around its tip, besides its center.
Rotation at tip allows location arrow to be shifted and offers more visibility in front.
- Map: change location arrow size (Pro)
Can adjust the location direction arrow’s size according to your preferences.
- Navigation: auto zoom with enhanced options (Pro)
Auto zoom options were revised, allowing now to select the min and max zoom levels.
Set different zoom levels for Dynamic mode or set same zoom levels for Fixed mode.
Dynamic zoom is now reactivated at some distance after passing the turn points for user convenience.
- Navigation: (optionally) amplify speech volume in voice guidance (Pro)
Can make spoken instructions louder than normal in active audio channel.
So that it’s easier to hear them or over other audio that might be playing.
- Navigation: option to prepare the phone call audio connection to avoid cut off instructions (Pro)
If set “Voice guidance output” to “Phone call audio”, then can adjust the timing of its connection with third-party devices, in order to avoid any cut off instructions.
- UI: long press on map, bookmarks or search results to copy coordinates in clipboard
Can copy coordinates in clipboard for various selected map elements via their popup dialog.
- Navigation: performance improvements (Pro)
We are looking forward to hear about your experience with this new version and new features. We wish you a nice Kurviger experience ![]()
