Kurviger 1.3 is on Google Play:
- Navigation: force a rerouting by tapping the warning sign when off route (Pro)
When being away from the route can trigger a rerouting by tapping the warning sign at top-center.
- Navigation: switch between distance / time to destination or next waypoint (tap distance) (Pro)
If tap the distance panel at top-right, both panels of remaining distance and remaining time (or ETA), switch to show information alternately for destination or next waypoint.
Panel symbol changes too to indicate for which selection the information is displayed (like attached images).
- Navigation: display remaining time or estimated time of arrival (tap time) (Pro)
If tap the time panel at top-right, the display switches alternately between remaining time or estimated time of arrival (ETA).
Note: both above distance + time display selections are remembered on app exit.
- Navigation: UI enhancements (Pro)
- Navigation panels have now a higher contrast
- Next instruction symbol and distance are larger
- Info panels display icons for easy identification
- Routing: option to show the waypoints in turn instructions
So far the waypoints were not included in turn instructions, treated more like shaping points.
Now there is a new option to include also the waypoints in turn instructions.
If enable it, that leads to announcement also of waypoints during navigation.
Note: the feature of display distance / time to next waypoint works anyway, either this option is enabled or not.
- Routing: change route line color
You can change the route line color with our new color picker.
With color presets and RGB color sliders for finer adjustment.
Hint: first option in color picker presets is current color (for easy revert).
- Routing: change route line width
Additionally the route line width can be changed in settings.
Route line rendering was revised, now being more clear and with slight increase per zoom.
- Map: change location marker / arrow color
You can also change the location marker / arrow color.
And don’t forget that can change location arrow size too.
See attached images for some ideas and features demonstration!
- Various improvements
There are enhancements in several areas as discussed in forum:
- GPX import
- Route (long press) menu
- Route auto-save
- Share actions
- …and many more
