Navigation startet nicht mehr 3.5.6
Heute eine Route geladen drücke auf Navigation starten aber läd nicht und das Batterie Symbol zittert hin und her.Neu gestartet neu eingelogt andere Routen geladen nix geht.Aktuelle Version.
Gruß Rolf
IOS oder Android?
Poste bitte die Debug Info aus den Enstellungen Menü (ganz unten). Jemand hat heute ein ähnliches Problem auf Android gemeldet, hat sich mit der Neuinstallation erledigt:
Since the update to 3.5.6 (Android version) the Kurviger App (active Tourer+ yearly subscription) won’t start navigation anymore. It doesn’t matter if it’s a pre planned route, a route from A to B, or a generated round trip: they all refuse to start navigation. Other navigation apps on my device do work.
For example: after making a route from A to B, I press “Start Navigation” and nothing happens. To be precise: the only thing I see happening is that the Android top bar (time, battery status, bluetooth and WIFI symbol) start flickering and moving left to right very fast. I find no difference between “recalculate route” on or off. This keeps on going until I restart the app or it crashes by itself.
Things I have tried that didn’t help solve this:
  • Restart my device
  • Reinstall the app
  • Log out and in again
  • Generate round trip and start navigation
  • Generate A to B trip and start navigation
  • Load and start a planned route
  • Start the route on WIFI
  • Start the route on personal hotspot
Unfortunately I cannot upload attachments as a new user. I have a screen recording of what happens: https://youtu.be/F0zH08hbqgA
Debug info:
OSM date stamp: 3/16/2025
Version: 3.5.6
Device: Topicon - T865 - Android: 14 - WebView: 133.0.6943.137
App-Version: 3.5.6 - 4841
Screen: 1138 x 712 px - 1.125dppx
Let me know if you need more information. Any help is appreciated.
Deinstalieren und neuinstalation helfen läuft wieder
Gruß Rolf
Perpaps as quickfix, in case it is urgent and if re-install does not help. You could leave Beta, uninstall and install latest stable (I assume Build 4841 is still beta?!).
Or you wait a lttle bit in case the devs have questions …
Well, I was out for a ride today and only found out it didn’t work after leaving home, so it was urgent but not anymore for me.
I don’t think this is a beta version. I don’t see an option to select beta anywhere, and I certainly didn’t mean to activate this. I use the stock app as far as I know.
I’ll wait and see what the response from others is before doing too much myself.
Thanks for reporting these issues. It’s interesting that somethings seems to be “stuck”.
It’s interesting that reinstalling the app did not solve the issue, in contrast to the other two reports we received.
Can you try what happens if you change the Day / Night settings in your Android settings? I am not sure if you have set your phone to light or dark, but try the other setting.
Have you tried what happens if you use the simulation instead of regular navigation?
Have you ever used Android Auto with Kurviger?
No :slight_smile: 4841 is in production for over a week now.
I had it set to “dark mode turns on at sun down”. So dark mode was off, I then turned it on and retried starting navigation: the same problem occurs.
No, I have never used Android auto with kurviger.
I tried this just now: this doesn’t work either and the same problem occurs.
-Edit: thanks for fixing the layout of my response :smile:
Ok, thanks for verifying this :+1:. One more idea: do you have auto screen rotation on or off in Android? Try the other setting, and try to start the navigation, when the route planning is in landscape. And please let us know if any of these help to fix the issue.
I have auto rotation “on”. After turning it off, the navigation still won’t start and I see the same “flickering” of the symbols as described in my original post. Note I did not restart my tablet (on which Kurviger is installed) after disabling it. Let me know if you’d like me to try that.
I always use the tablet in landscape mode when starting navigation and when using it during navigation. After putting it in portrait mode (?) the navigation still won’t start and I see the same “flickering” of the symbols as described in my original post.
Just FYI: between each “test” I close the Kurviger app by “swiping it away” and restarting it. Let me know if this is not the best approach for testing these possible fixes.
Also, the navigation won’t start on my mobile phone (One Plus Nord 2 5G) either. It has the same symptoms when trying to start navigation: flickering of the top row of symbols (wifi, bluetooth etc.). I hope this doesn’t clutter the original problem, just thought it might help with the troubleshooting.
Debug info for Kurviger on my phone:
OSM-Datumstempel: 18-3-2025
Versie: 3.5.6
Device: OnePlus - DN2103 - Android: 13 - WebView: 133.0.6943.138
Screen: 360 x 800 px - 3dppx
Xiaomi Redmi phone:
I can start a planned tour, see it on the display. When I press “Navigation starten” I see the turning circle, but no further activity except flickering statusline.
Note: Works good with Samsung Galaxy.
I am Tourer+
Can you post the debug data of the device where it does not work?
Also check the above messages, for some people deinstalling and reinstalling the app solved the problem.
Yes, that is a good approach (if the app was not started with a symbol in the status bar).
I have one more idea:
@Horst_Gutzki and @FireRider5132 - did you by any chance recently load an old .kurviger file or an old URL?
Just to make sure, please try to open this URL or
this .kurviger file (1.7 KB) on your phone and try to start the simulation or navigation (it’s just a random route, but hopefully this should reset a possible issue that you might had).
No, I’m a new user so I don’t think I have any files like that. I make the routes on Kurviger desktop in my browser and open it on my navigation tablet through the Kurviger app.
I tried this just now: simulate navigation gives the same problem (flickering of the top bar symbols). Start navigation gives the same problem.
Is there any way I can roll back the update as a temporary fix? If this were to happen during a multiple day trip, it would be very annoying. I have an alternative app, but I chose Kurviger for a reason :smile:
Thanks for the suggestions so far. Keep me in the loop please.
Ich bin bei der aktuellen Kurviger App (vom 11.03.25 keine Beta) von der Free Version zur Tourer+ gewechselt.
Jetzt funktioniert die Navigation nicht.
Start und Stop gesetzt ( 25 Km, ohne Zwischenziel oder Shaping Point).
Drücke unten rechts auf das Navigations-Dreieck.
Button Navigation starten erscheint und drücke dort drauf.
Dann sehe ich meine Position und die nächsten ca.100 Meter incl. der Karte.
Danach tut sich nichts mehr. Nach ein paar Minuten erscheint die meldung “kurviger reagiert nicht. Warten oder App Schließen”.
Habe ein Samsung J5 mit Android 7.1.1
Könnt Ihr mir weiterhelfen ?
Aktuell haben scheinbar mehrere User ein ähnliches Problem - die Fehlersuche läuft:
siehe Beitragsverlauf.
Bei manchen hat geholfen, die App zu deinstallieren und dann wieder neu zu installieren.
Das habe ich schon ausprobiert. Hat leider nichts verändert.
Du könntest evtl. die Vorschläge aus den obigen Posts ausprobieren, hat aber scheinbar bisher nichts davon gewirkt. Ansonsten müsste man sich gedulden, bis der @boldtrn den nächsten Vorschlag bringt.
Könntest du die Debug-Info aus den “Einstellungen” (ganz unten) posten? Man muss sie nur antippen zum Kopieren und dann in einen Post einfügen. Dies hilft den Entwicklern möglicherweise bei der Fehlersuche.
Ich habe die obigen Sachen jetzt ausprobiert. Leider keine Verbesserung.
OSM-Datumsstempel: 20.3.2025
Version: 3.5.6
Device: samsung - SM-J510FN -
Android: 7.1.1 -
WebView: 119.0.6045.193
Screen: 360 x 640 px - 2dppx
I found the issue, please make sure you grant all permissions for the Kurviger app. It seems that if you decline a permission the app can be stuck. We will fix this issue with the next update, in the meantime, please grant all permissions.
Ah, ich weiß woran es liegt. Bitte gebt Kurviger alle Berechtigungen, dann startet die App. Scheinbar hat sich hier ein Fehler eingeschlichen, wenn z.B. die “Benachrichtungen anzeigen” Berechtigung nicht gegeben wird, dann hängt die App. Da hat sich scheinbar ein Fehler eingeschlichen.
@Gerold70 - ich bin mir nicht sicher, ob das auch das Lösung für Android 7.1.1 ist. Eventuell liegt hier das Problem an der alten Android Version in Kombination mit den Berechtigungen, da es diese Berechtigungen für Android 7 noch nicht gab.
